Browse Forums Paving & Concreting 1 Jun 01, 2019 5:56 pm I need to tile my back yard around my pool. The pool coping tile is 35 mm thick and the tile I’m laying is 10mm thick so there will be 25mm under the tile. I can’t find a tile adhesive that can be laid that thick. Can anyone recommend a suitable product I could use. Would mortar work? Do I need to raise the level of the concrete with a self leveling product? First time taking on a project like this. Any advice will be much appreciated. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Tiling Advice 2Jun 01, 2019 8:44 pm You'll need to lay a screed bed first and then tile. I'd prime the existing concrete slab with bondcrete or similar primer and then lay in the screed bed allowing for tile and adhesive. Screed is a fairly dry mix of sand and cement that can be spread out and levelled to a firm hard surface. It's the same principle that's used to get the falls in the wet areas inside a house. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Looking to tile the facade pillars rather than rendering. Builder is quoting 2500$ laying cost for upto 10msq. The 2 pillars come to be 16msq. So laying costs are 5000$… 0 8144 Hi, I'm clearing the tiles from our horrid 50 year old bathroom and preparing to lay new ones. Bugger of a job getting the old… 0 8328 4 15076 |
