Browse Forums Paving & Concreting 1 Aug 04, 2023 10:41 am Attached photo Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Should the tile be grouted under the cover plate? Pool area was extended and slab laid. Then spigot core drilled and set in place. Then screed and waterproofing. Then tiler came and did tiling and cut the tiles with hole for the spigot so just laid over it. They grouted all rest of tile lines but not around spigot. Does it matter, the cover plate is cover the hole so it doesn’t look wrong but wasn’t sure if corner has been cut by not filling in grout? Re: Grout tile around spigot? 2Aug 05, 2023 11:41 am This is the way its generally completed, tiler will not grout around spigot as any movement on spigot will just crack the grout. This should be finished with an external grade sealant to prevent water entering under the tiles and this will allow for movement. Make sure sealant is compatible to waterproofing as sometimes they can react to each other, if unsure get waterproofer back to complete the filling around the spigots. Re: Grout tile around spigot? 3Aug 05, 2023 12:04 pm Thanks splashers, that makes sense. The waterproofing guy used this Davco product, I will raise the issue with builder and hopefully get resolved with him - if not will do myself can you see being issue with using any sealant with this davco product or would I need to speak to davco to see what they recommend? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Have some black tiles in our bathroom on one feature wall laid on top of the waterproofing. What I think is efflorescence or white chalky looking grout has turned the… 0 2597 Hi everyone, Have just put a shower in the laundry and after only using it 2-3 times have noticed staining on the grout. The tiles were glued onto a concrete wall after… 0 5831 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 9020 |
