Browse Forums Paving & Concreting 1 Nov 04, 2022 8:08 pm Hi there, We just bought a house which has a driveway that looks like it was resurfaced with something, probably to cover the cracked concrete underneath. Anyways that something is now crumbling and lifting on places, so it looks terrible. So my question is, does anyone know what the stuff is that's on the driveway? And secondly how can I remove it? Thanks Tristan Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Remove coating on concrete driveway 2Nov 05, 2022 1:47 am It's probably pebblecrete or something similar. The only way to remove it is mechanically. Basically jackhammer and then grind to remove any left over. There are companies that do it if you don't want to hire the machines. The other issue is the actual concrete substrate that is obviously broken. Depending on your long term goal you might be better of to just remove the existing concrete, coating and all and then install new concrete. It will cost you more but will only do the job once. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6306 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12498 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7362 |
