Browse Forums Paving & Concreting Re: Honed V Exposed Aggregrate Pool Area 2Sep 23, 2022 11:19 pm SamMac What is the difference between honed and exposed? Will be doing in a pool area. Thanks. In both you see the stone used as the aggregate. With exposed a chemical is used to prevent the top few mm's of concrete from hardening. This is then washed away exposing the aggregate. Depending on the methods used for the wash off it leaves from a slightly textured finish to quite an aggressive level of finish. Honed is basically finished like standard concrete and then floor grinders are run over the top. It's basically the same as the first step in a full polish but they basically cut back until you see the stone but don't keep polishing with finer pads so it's always a smooth matte finish. Around a pool and particularly if you are going to pour the overhang of the pool with the deck I'd always opt for honed. It's nicer under bare feet and a smoother edge if you drag yourself out over the side of the pool. If you have a coping in place a lower exposurer washed finish will be fine and much cheaper Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Honed V Exposed Aggregrate Pool Area 3Sep 24, 2022 11:33 am chippy SamMac What is the difference between honed and exposed? Will be doing in a pool area. Thanks. In both you see the stone used as the aggregate. With exposed a chemical is used to prevent the top few mm's of concrete from hardening. This is then washed away exposing the aggregate. Depending on the methods used for the wash off it leaves from a slightly textured finish to quite an aggressive level of finish. Honed is basically finished like standard concrete and then floor grinders are run over the top. It's basically the same as the first step in a full polish but they basically cut back until you see the stone but don't keep polishing with finer pads so it's always a smooth matte finish. Around a pool and particularly if you are going to pour the overhang of the pool with the deck I'd always opt for honed. It's nicer under bare feet and a smoother edge if you drag yourself out over the side of the pool. If you have a coping in place a lower exposurer washed finish will be fine and much cheaper Thanks mate. We’re doing a coping paver around the pool, then concreting the remainder of the pool area. CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17066 Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 11138 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10647 |
