Browse Forums Paving & Concreting Re: Concrete footing 2Jun 24, 2022 9:25 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Concrete footing 4Jun 25, 2022 10:31 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Concrete footing 6Jun 25, 2022 12:01 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete footing 8Jul 08, 2022 10:05 am Pulse You really need an engineer to specify the detail of how it is joined, don’t necessarily need to pull it out altogether, there would be a way around it. If it is a small distance on council land it probably doesn’t matter too much. Its a total length of 7.5m. The idea is to dig a trench next to it, drill holes in the existing footing and insert rebars to hold them together. Im a bit iffy about it but at the same time im not a builder or engineer so dont know if its sufficient or not for the purpose of a 1.2m brick fence PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10780 I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3754 there is a standard besser block wall pdf somewhere online with footing sizes, also have a look at dincel. 1 3409 |
