Browse Forums Paving & Concreting 1 Apr 29, 2022 4:52 am Hi all, I am laying a driveway and am having concrete around the perimeter of my house. I have a waffle slab and need to protect the slab from water ingress. The concrete must drain the water away from the slab. and it must hold it's position over time so as not to lose this function of draining the water away. I have enlisted a concretor but am unsure what to look for in their procedure to ensure they are doing everything properly. If someone with expertise or experience could comment that would be great. Thanks, Re: Proper method for laying concrete 2Apr 29, 2022 10:06 am Hey lakshman Welcome to the forum Best thing to do is get a site plan prepared with certified engineers Drawings and Details. Get 3 concretors to quote on them Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Proper method for laying concrete 3Apr 29, 2022 4:35 pm There is sufficient information on this forum for you to find what you need if you do your homework, if not then pay independent inspector to guide you. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Proper method for laying concrete 4Apr 30, 2022 10:29 am Funny thing about driveways and cross overs Council don't give a Sh!t about your drive way drawings, details and construction until there's a cross over onto Council property. Then they throw the rule book at you if its non compliant Why don't you call them, ask for their engineering department and quiz them Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Proper method for laying concrete 5May 03, 2022 6:34 am Lakshman Hi all, I am laying a driveway and am having concrete around the perimeter of my house. I have a waffle slab and need to protect the slab from water ingress. The concrete must drain the water away from the slab. and it must hold it's position over time so as not to lose this function of draining the water away. I have enlisted a concretor but am unsure what to look for in their procedure to ensure they are doing everything properly. If someone with expertise or experience could comment that would be great. Thanks, Ask the Concreter how the drainage works. Even tell them you’re concerned about damp getting into the structure and causing damage or worse (mold got into my bedroom and I thought I had strep throat or tonsillitis for a couple days till I discovered it spreading out from behind the desk. I closed off the room and slept in the lounge till I got rid of it within 3 days I was back to me usual self. It can mess you up, the concreter would understand you querying how it all works I'm based in Adelaide and I'm considering purchasing a house and land package from Weeks Homes. I found a deal that looks good, but there's a complication: the land isn't… 0 690 I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 2633 Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4887 |
