Browse Forums Paving & Concreting Re: No isolation joint between driveway and slab, dowel used 3Mar 17, 2020 7:51 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: No isolation joint between driveway and slab, dowel used 4Mar 17, 2020 7:58 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: No isolation joint between driveway and slab, dowel used 8Mar 17, 2020 6:32 pm And that is why we don't install rebar dowels externally, it rusts->expands, cracking the concrete over time more importantly, the concretor hasn't followed the engineers details and you haven't got photos of what's been done Keep an eye on it over time Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4839 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2908 The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work. You might… 7 9942 |
