Browse Forums Paving & Concreting Re: Concrete paving against brickwork 2Mar 17, 2019 8:49 am Regulations are applicable to the distance between the finished surface level and the DPC. Various sub regulations exist applicable to the area's ARI and whether the finished surface is in an open area, a 'covered' area or an enclosed area. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. DIY, Home Maintenance & Repair I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing… 1 5451 6 4578 Good on you for having a go I am the opposite of DIY (so will pay a builder) - our vibe is industrial/simple so current thinking is 150mm concrete and then internally is… 3 1370 |
