Browse Forums Bathrooms and Laundry 1 Jul 19, 2020 11:17 pm Can anyone advise me of the following. 1 The gap between the glass door and wall when using a glass to wall hinge (offset) 2 The gap between the door and fixed panel. 3 The gap between the fixed panel and wall when using wall brackets (not channel) and to be sealed with silicon,and the best type of silicon for this. Thanks. Re: frameless glass shower screen gaps 2Jul 20, 2020 8:46 am oldchippy Can anyone advise me of the following. 1 The gap between the glass door and wall when using a glass to wall hinge (offset) 2 The gap between the door and fixed panel. 3 The gap between the fixed panel and wall when using wall brackets (not channel) and to be sealed with silicon,and the best type of silicon for this. Thanks. 2 4635 Your shower screen has failed in the way it is designed to fail with tempered glass. You could replace it with laminated safety glass but make sure it has AS standards logo on it 1 11403 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7745 |
