Browse Forums Bathrooms and Laundry 1 Dec 21, 2016 4:26 pm My laundry conversion tap set (2 handles 2 outlets per side) is leaking through the laundry outlet. Pic is of the laundry tap. I am looking to replace the white tip as there is no other washer in the assembly. Have rung 6 different plumbing shops and Bunnings and everyone only sells an entire tap set which is expensive. Does anyone know if only the this part can be sourced or any other ideas to fix this leak? From the information posted it looks to me your rumpus room is nothing more than extended garage. That will present a number of challenges. Single brick wall between… 2 7993 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11568 Because it only states 90mm not if it’s 45mm or 35mm and yes I do have the plans my question was specifically since it’s not the structural value and only to hold… 2 3624 |
