Browse Forums Bathrooms and Laundry 1 Jul 23, 2016 12:51 pm Hi all My apologies if this as been discussed before. I am planning to build a new house and I have been thinking of a design for an easy clean (low maintenance) design for the shower area. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Above design for an instance is minimalistic however still inherits the problem of difficulty in cleaning using a scrub brush at corners. My initial thinking to avoid this issue of difficulty is to eliminate corners where three planes intersect. Only way to achieve that is to make the corners spherical. I then imagined myself inside an egg - that's how it will be. There will be no corners anyway and it will be so easy to clean. Are there current designs that you guys have thought of or came across that helps to easily clean the shower? DIY, Home Maintenance & Repair I mean, I install them/sell them for a living so I haven't done DIY, unless you count the first one I installed lol. (electrician by trade). Usually a 6-8 hour job for… 3 42327 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17634 I have stone pavement (?) in my backyard around the pool. I have not tended to them and so there is moss growing on them. I intend to clean them but was wondering what the… 0 2770 |
