Browse Forums Bathrooms and Laundry 1 Nov 15, 2015 1:43 pm So, building a 9x6m shed in the backyard, plan currently is to make one of the bays (so 3x6m) lined/insulated, and turn it into a spare room, with bathroom. Originally planned on just putting a toilet/basin in there but suggestions from mates that I should add a shower too - I have to get the plumbing put into the slab when it's laid, so figured worst case I don't use the shower drain. The issue I'm having is with layout. Ideally I'd like to take up the least amount of space - it's really a 'shed bathroom' but can't be unusable. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I based this layout off the Ibis Adelaide's bathrooms, their showers are tiled and a little bigger, and the toilet is on the same wall as the basin (I'm not sold on either side, just happens to be where it ended up). In their rooms, the cutout from the L shape is a cupboard on the outside. Thoughts? I'm assuming I'll only need shower drain, floor drain, and toilet waste into the slab - incoming water and basin drain will be into the wall. Cheers, Nick Re: Small bathroom in new shed. 3Nov 17, 2015 7:03 am tjilpi You could make it 1000 x 3000 (or 1200 x 3000) and have the shower across one end, toilet at the other end with the vanity in the centre on the back wall, and a central door. That was my initial thought, but that seems to take up more room than a smaller square/L shaped one. Re: Small bathroom in new shed. 6Nov 17, 2015 5:59 pm It'll be connected into the septic, outlet from the shed will be about where the basin is. Re: Small bathroom in new shed. 7Nov 17, 2015 7:26 pm Spin shower 180 degress, run pipe out there using a smart pan on a dt trap. Once out that will be where vent goes then run pipe.along back shed picking up toilet. Run basin out where is and that will.be the feed for the org there and then into the septic easy done☺ Re: Small bathroom in new shed. 10Nov 18, 2015 9:39 am Absolutely, I figured if I've got at least a semi-decent plan when I go to qualified mates to check, it'll save their time (and my beer). Thankyou for your advice. We do have Caesar coming out and hopefully resolve the issue for us. 4 19499 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5846 Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3716 |
