Browse Forums Bathrooms and Laundry 1 Jun 22, 2015 5:18 pm we built a new home a little over two years ago. We have a hobless shower and it appears there is no fall on the tiling .... something I picked up from the fab reno shows on tv .... so every.single.time we use the shower the water slowly creeps out and floods the bathroom - it has come to the point that we no longer use that bathroom. Any suggestions on how to fix this or if I should contact the builder if it would be up to them to repair? I have not tried a different shower head but I am wondering fixing the issue could be as simple as changing the showerhead? thanks in advance for any suggestions. Re: Hobless shower leaking in new home. 2Jun 25, 2015 6:58 am The only way changing a shower head would help is if it was a water saver head that halved the flow. Not worth considering! Call the builder!!!! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Hobless shower leaking in new home. 3Jun 25, 2015 7:51 am Yes - surely a warranty issue ? But - do people use hobs anymore ? Re: Hobless shower leaking in new home. 4Jun 25, 2015 7:51 am Otherwise it may be a re-tile and seal etc. DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 25061 My first suspect area is at the bottom of the harvested downpipe furthest from the tank. PVC downpipes expand and contract with heat and cold, putting pressure on the… 3 2418 8 4403 |
