Browse Forums Bathrooms and Laundry 1 Oct 25, 2014 9:21 am Our factory build is under way at long last, but we've had an odd issue with the builder. I am finding it difficult to negotiate a solution, since I am in California and the factory is in Melbourne. I'm hoping an experienced cabinetry installer or bathroom/kitchen reno firm out there can give me some insight? The laundry tub was specified as a Clark 45L Flushline 'compact configuration' stainless steel tub, edge to edge dimensions of 480 x 640 mm (the tub itself being, of course, rather smaller). The compact configuration means that the bigger dimension (640mm) running front to back on the bench. Its to be mounted through a laminate benchtop into a cabinet that is 570 x 700mm (internal measurements of 538 x 670). The builder is insisting that the cabinet is too small, and wants to substitute the MUCH smaller Clark 30L. The builder's in-house design team specified the cabinet size and drew up the plans after I picked the sink. The current reason (this is rationale #3) for the too-smallness is that the installer "can't get his hands inside the narrow spaces left over inside the cabinet to fasten the sink clips". Can someone who has installed a stainless sink like this share? Because it seems like (a) the cabinet is just big enough (although maybe maybe 750mm deep would have been better) and (b) if there really isn't a tool to tighten the clips with, couldn't they just install the sink before they put the bench on top of the cabinets? Wouldn't work with stone or a porcelain tub, maybe, but stainless and laminate...? (Remembering always that this is a factory build, so they don't need to run hither thither and yon to find tools or trades.) I'd run over there with my cordless screw driver and a magnetic extension bit, but the $3000 for airfare makes it prohibitive. I've just now fallen back on digging my heels in, and telling them to figure it out. So --is the cabinet big enough? If not, isn't the builder responsible for coming up with a solution acceptable to me, or at least a reasonable compromise? Chris On the threshold of retirement... and trying to check my assumptions at the door Re: Tight fit on laundry tub; builder balking -help! 2Oct 25, 2014 3:37 pm I think the builder is right. I doubt its about the clips, you just silicone it down and it would never move. I think there would be an issue with the size of the sink as you may have to cut the carcass/frame of the kitchen to make it fit. You'll fit a 600mm (front to back) sink no problem. Either rotate the existing sink or get a smaller one. Re: Tight fit on laundry tub; builder balking -help! 3Jan 24, 2015 12:37 pm I found my answer here on Homeone! I convinced the builder to substitute an Oliveri 45l tub that has a slightly smaller footprint. Chris On the threshold of retirement... and trying to check my assumptions at the door Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is… 0 11981 This is the current bathroom with a european laundry. Overall internal dimensions are 3.69 wide and 3.65m deep, including the footprint of the laundry. There is a toilet… 0 11364 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 13574 |
