Browse Forums Bathrooms and Laundry 1 Jul 16, 2014 12:37 pm I have instantaneous hot water and a mixer tap in the shower, both installed less than 2 years ago. When I turn on the tap all is fine, but when the water heats up the shower emits and annoying whine. When I reduce the temperature or the pressure the noise goes away. What I do not understand is that as the temperature of the water increases the pressure does not change so why does reducing it fix the problem. Where do I start, the shower head or the mixer tap? I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9967 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 6076 Ask yourself if the insurance company will be aware of the Reno. 4 7750 |
