Browse Forums Bathrooms and Laundry 1 May 01, 2014 1:54 pm Hi folks, Sorry to be asking a question with my very first post, but I couldn't justify calling out a plumber for something that I should be able to fix myself. The problem we have is that water is coming out of the little overflow tube thingy under our laundry sink. This happens whenever we have more than a trickle flowing from the laundry tap, and every time the washing machine purges water into the sink. We have had this problem ever since we moved into the house about 9 months ago. It's quite annoying, as anything we store in this little cabinet under the sink has to be in water-proofed bags, and it is always musty. I have checked the pipes, and there don't appear to be any blockages. Can I simply plug-up this little overflow tube? Or can I go to bunnings and buy a different pipe orientation to screw in? Any help would be greatly appreciated. Please see photos attached. The little tube where the water comes from is clearly visible in the close-up photo. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Small plumbing problem under laundry sink 2May 01, 2014 5:03 pm Do you mean the little spigot off the side?? Its not an overflow. Its there to allow a washing machine or dishwasher drain to be connected. Its normally blanked off and you have to drill it out to use it. I would block it off. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6362 Hi Sillysausage1900, Hope all is well. I came across this forum as Im somewhat same situation with you regarding Roof Plumbing certificate requirement. Im requesting a… 4 9469 |
