Browse Forums Bathrooms and Laundry 1 May 29, 2013 5:29 am I'm using Hardie's Scyon Secura interior floor sheets on a bathroom renovation, and I understand that any cut edges will need to be sealed to keep them water-resistant, but I don't know what product to use to do that. Does anyone here know? The Scyon Secura *exterior* sheeting installation instructions (Hardie's pdf file) states that "Wattle Killrust Heavy Duty Primer" (?) should be used to seal any cut edges, but I can't find any mention in the Scyon Secura *interior* sheeting installation instructions, of what to use on those sheets. Re: Sealing cut edges on Hardies Scyon Secura interior floor 2Jun 07, 2013 8:44 am Pretty sure for wet areas you leave a gap [2mm] and fill with sealant. Therefore painting not required. Landscape Design & Construction http://cherub.squarespace.com/ Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7415 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 6705 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10839 |
