Browse Forums Bathrooms and Laundry 1 Nov 27, 2009 9:44 pm I need an expert's advice about screeding the slab in the bathroom. The difference in level between the concrete there and the estimated finished floor level elsewhere is approx 57mm. Into this I need to: stick on 10mm thick Marmox insulation board on a 5mm of glue, put on top a 2mm thick wire mesh, tie down to it 6mm thick electric floor heating cable. All this adds up to approx 23mm, leaving 35 mm for the concrete screed, tiles and their glue. Less 10mm for glue and tiles it's 25mm only for the screed at the thickest point, less around floor waste. Is this enough ? Because if it isn't, I'll have to forget about Marmox insulation. I'm getting conflicting advice from tilers and floor heating suppliers and I hope someone will clarify the issue for me. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Bath Floor Screed thickness? 2Nov 27, 2009 9:58 pm Hello I would be using a suitable waterproofing membrane so another 2mm ... yes 23mm dry pack is fine down to about 15mm... any less and I would using a specialized product. Nothing that has lime in it Almost dry, damp sand/cement mixed homogenous(sp?) and grit could be used as an extender (aggregate) no more in size than 1/3 the screed thickness at the thinest point any good So far no failures lots completed Where you are coming from is where you are going to... Re: Bath Floor Screed thickness? 3Nov 28, 2009 11:07 am onc_artisan Hello ... yes 23mm dry pack is fine down to about 15mm... any less and I would using a specialized product. Nothing that has lime in it Almost dry, damp sand/cement mixed homogenous(sp?) and grit could be used as an extender (aggregate) no more in size than 1/3 the screed thickness at the thinest point any good So far no failures lots completed Thanks Onc, How about latex or acrylic additives, ex Bondcrete, to make it stick better and crack less ? Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Bath Floor Screed thickness? 4Nov 28, 2009 11:24 am If you use a bonding agent make sure it is not PVA. or it must be cross linked (so when it cures it CAN NOT re-imulsify (spelling is crap without FF or Modz ) Bondcrete is an admix not a bonding agent (not for me anyway in a wet area). There are plenty( a tile shop will have what you want) ... but ask for what you want or you might be unlucky The screed will set hard and the waterproof membrane will cover any defects Where you are coming from is where you are going to... Re: Bath Floor Screed thickness? 5Nov 28, 2009 3:35 pm hi, hope this sheds some light.
In SA (regs vary from state to state slightly) they recommend a fall of 1:100 for the main floor, ie 10mm drop per m, so the size of the bathroom needs to be taken into account. (a 2m wide room with a floor trap in the middle will need a drop of 10mm, but if the room is 6m wide you will need a 30mm drop) Your shower is a seperate issue again and needs a steaper fall, but this shouldnt be a problem as you could always put in a hobb if necessary. In addition the top of the tiles is usually 10mm above the finished floor level, and will then blend in with a carpet or tile floor in your ajoining rooms, so you may really have 67mm to work with. Hopr this is of some use. Re: Bath Floor Screed thickness? 6Nov 28, 2009 3:59 pm Good pick up Hills Guy Where you are coming from is where you are going to... Re: Bath Floor Screed thickness? 7Nov 28, 2009 6:30 pm onc_artisan If you use a bonding agent make sure it is not PVA. or it must be cross linked (so when it cures it CAN NOT re-imulsify (spelling is crap without FF or Modz ) Bondcrete is an admix not a bonding agent (not for me anyway in a wet area). There are plenty( a tile shop will have what you want) ... but ask for what you want or you might be unlucky The screed will set hard and the waterproof membrane will cover any defects Excuse my ignorance, but what "cross linked" means in this particular case ? Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Bath Floor Screed thickness? 8Nov 28, 2009 6:32 pm The primer will be 'chemically cured' not a chemist but I have seen the results of the difference. Oposed to evaparating water. Where you are coming from is where you are going to... Before you rip it up, if you can in the grout lines, drill some holes and pour/inject techgrip by sika. I have used it to bond mdf to timber, but in the process it dripped… 1 4486 Hi all, We're curring working on our outdoor and have some questions in relation to screed. I've tried to find information online, without success. Apologies for the… 0 3408 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 5202 |
