Browse Forums Bathrooms and Laundry 1 Jan 23, 2024 7:38 am Hi everyone, Just wondering if anyone has switched from a small square tile insert or normal square waste to a strip drain at all, and if so did the plumber or diy-er chipped out a channel to the 100mm waste via a 50mm PVC pipe to the new strip drain location? I am thinking of doing that so I can avoid some tricky relief cuts in my tiles as I am wanting to use 600 X 300 tiles. Thanks Geoff Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4666 Agreed. I just found out today the certifier has not given the final sign off. 2 4216 |
