Browse Forums Bathrooms and Laundry Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 8200 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12826 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 3057 |
