Browse Forums Bathrooms and Laundry brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7838 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7743 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12665 |
