Browse Forums Bathrooms and Laundry 1 Jun 13, 2023 9:03 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I need to mount a ~25kg shaving cabinet to a bathroom wall. There are only 2 mounting points. After drilling pilot holes, I have found that there is about 8mm of Villaboard then 8mm of an airgap before a shared brick wall. Just wondering what the best method for mounting/anchoring the shaving cabinet is, ideally without having to drill in to the brick wall. Re: What anchor/screw to use to mount to villaboard>airgap>b 2Jun 13, 2023 10:27 pm There should be some framing as well? You would need to attach your cabinet to a stud, ideally. However, villaboard is capable of holding 50 kg/m2 of tiles, so with multiple screws it should be able to hold 25 kg cabinet, too. Re: What anchor/screw to use to mount to villaboard>airgap>b 3Jun 13, 2023 11:08 pm alexp79 There should be some framing as well? You would need to attach your cabinet to a stud, ideally. However, villaboard is capable of holding 50 kg/m2 of tiles, so with multiple screws it should be able to hold 25 kg cabinet, too. Thanks! The cabinet will hang off the 2 screws, and there are no studs anywhere near where I need it to hang. Is there a particular kind of screw that is best to go straight in to the villaboard? Unfortunately I can't find anchors that are short enough to fit before hitting the brick. Re: What anchor/screw to use to mount to villaboard>airgap>b 4Jun 14, 2023 12:34 am If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with adhesive. The dobs of adhesive hold it off the brick work a small amount. There is no way of fixing your cabinet just to the villaboard. You need to drill right through and into the brickwork. Fortunately it's an easy fix. Just use a 50mm plug and screw. Drill right through villaboard and into the brick, tap in your plug flush with the wall and screw in a 50mm selftapper. It will be plenty strong enough to hold up a shaving cabinet. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Hi All, First time poster. I was hoping to get some advice on villaboard installation within a bathroom. I have installed villaboard before, in a laundry. I think I did… 0 7641 That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 18264 I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17679 |
