Browse Forums Bathrooms and Laundry 1 Oct 30, 2022 3:40 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi, I'm trying to install a new bathtub spout (the estilo chrome bath set from Bunnings). But I'm having a problem because I can't screw on the new spout far enough to make contact with the wall - there's a gap of about 1-2 mm. I can screw it a bit further than this to get it closer but this means that it doesn't end up pointing down into the bath. I have a few questions: 1) Is it a problem if there is a small gap? If so, is there something I can do to prevent any problems? 2) Is there a way to get the spout to screw on further? I think part of the problem is that the thread I'm screwing on to has build-up at one end which increases friction and makes it harder to screw on. I've brushed a lot of this away which has helped tremendously. Any thoughts would be great thank you. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10635 DIY, Home Maintenance & Repair Follow up question - any ideas on how to set up a portable air conditioner through this kind of window? 1 6814 I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 1402 |
