Browse Forums Bathrooms and Laundry 1 Apr 26, 2022 5:56 pm Recently I have begun to notice a dripping sound that seems to be from UNDER the shower tiles. Once all taps are turned off, and other visible sources of water drips dealt with (shower head, soap holder, shampoo shelf, etc), I am able to isolate a dripping sound under the tiles. It's on the opposite side to anything that could be dripping on the wall, and it also doesn't sound to be coming from the drainage hole as I can locate its own dripping sounds. I'm no expert on tiling, but I was under the impression that directly under shower tiles is a solid surface that it sits on. So what could possibly be dripping underneath it? Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 6044 looks experimental to me, reinforced screed would be a better option or even better insulate between ground and structural slab. I would not put granite over that,… 3 5202 I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 4987 |
