Browse Forums Bathrooms and Laundry 1 Apr 18, 2022 11:46 pm Hi, can I please get some advice? I have just moved into a house where the laundry tub does not have a bypass hole in the sink. We have just had it draining into the sink, but it has accidentally overflowed a few times so I want to plumb it in. Other than buying a new sink with a waste bypass kit, how can I do this? To me it looks like the waste connection is for a dishwasher hose only - is that right? If I want to connect the washing machine waste, do I need to buy a new p-trap similar to the one in this link? :https://i.ebayimg.com/images/g/YPIAAOSwrhBZEvuu/s-l400.jpg Will I even be able to connect the waste hose if it is rigid plastic? Or does it need to be rubber in order to connect to a waste outlet on a p trap? Or am I better off replacing the sink with one with a bypass? Is that a better outcome, or same same? Photos attached Thanks! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Plumbing washing machine waste drain hose 2Apr 19, 2022 8:02 am freakstorm4 To me it looks like the waste connection is for a dishwasher hose only - is that right? Will I even be able to connect the waste hose if it is rigid plastic? Or does it need to be rubber in order to connect to a waste outlet on a p trap? Our washing machine drain hose connects to the "dishwasher outlet". Does your hose not have a rubber end? If not, perhaps you could contact the washing machine manufacture to see if they have an available solution. Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the… 0 17880 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4709 Agreed. I just found out today the certifier has not given the final sign off. 2 4239 |
