Browse Forums Bathrooms and Laundry 1 Sep 19, 2021 3:58 pm Hi can anyone please help me? This knob switches the shower head from the overhead rain shower to a hand held head. It’s a brand new set. The knob came off and I can’t work out how it’s supposed to work. Seems like the dumbest design I’ve ever seen. The brass inner is completely smooth so nothing to lock onto. The screw that is supposed to lock on to the brass only just pokes through, so not much purchase there. Then the black switch handle also screws off so that makes it harder to adjust. Finally there is no indication on the base (like a little arrow or something) to show where to turn to. I have tried screwing it in and off several times but it won’t stay on at all. Any idea? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Shower adjustment thing 3Sep 21, 2021 8:16 pm Look like a similar design to this volume knob which attaches to a smooth post with a set screw and comes loose every 2nd time you turn it. Crap design for sure. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Can you screw that one in with a screwdriver? Like this one: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ If so, attach the big knob first and fasten the screw as tight as you can. Then attach the small knob to the bit of the screw which protrudes out from the big knob. I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 10256 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 6243 |
