Browse Forums Bathrooms and Laundry 1 Aug 01, 2021 12:58 pm Does anyone know if you can use wall hung basins on a counter instead of hung to the wall? I may not be explaining right. It will still be against the wall but will have a counter under it as well. I'm having trouble finding a basin to fit (small vanity) for a counter top basin but have found plenty that are wall hung. Re: wall hung basin on counter? 2Aug 01, 2021 1:01 pm wendlle Does anyone know if you can use wall hung basins on a counter instead of hung to the wall? I may not be explaining right. It will still be against the wall but will have a counter under it as well. I'm having trouble finding a basin to fit (small vanity) for a counter top basin but have found plenty that are wall hung. So this vanity is marked as wall hung or counter top so can be used in either way. Its only 250 deep. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 6764 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 5576 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17878 |
