Browse Forums Bathrooms and Laundry 1 May 09, 2021 3:22 pm The water level in our ensuite toilet bowl drops over a period of time (never timed) generally overnight, sometimes it drops low enough to allow foul air into the ensuite from the waste pipe. I cannot see any water coming out from under the toilet onto the tiled floor, so it has me confused as to where the water is going. Our 2nd toilet in the opposite corner of our home has no such issue. Can somebody give me a clue as to what is happening and a possible solution to the problem. Re: Toilet Bowl Level 3May 09, 2021 5:44 pm The worked perfectly for the 1st 12 months now it has gone weird. Thanks for your reply, will get the vent pipe checked out first. Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 5200 "Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets 36 25229 I have a toilet that blocks up on the top (2nd) floor of a property. The toilets on the 1st and ground floor are OK) Blockage clears when the using a plunger. But… 0 1099 |
