Browse Forums Bathrooms and Laundry 1 Sep 28, 2020 1:51 pm Bought a new apartment a year ago and noticed several building quality issues after moving in, including terrible sewage smell from one of the bathroom. Further investigation found that the water trap is missing from the floor trap.
Had tried to contact the builder but no any response for more than a year. Advice needed regarding the warranty issue of this type, and who will be the best person to contact if builder is not taking responsibility. Thanks. Re: Builder forgot to install floor water trap in bathroom 2Sep 29, 2020 3:26 pm Any advice will be appreciated. Following is the illustration of floor trap installed in the other bathroom of my apartment. After compared apple to apple, the PVC insert is missing in one of the bathroom. Re: No floor water trap in Bathroom? 3Sep 29, 2020 8:45 pm Not all floor waste gullys have that removable water trap. It all depends where the actual trap is. More often than not it's after the gully. Did you get a plumber to inspect? Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: No floor water trap in Bathroom? 6May 02, 2021 2:30 am chippy Not all floor waste gullys have that removable water trap. It all depends where the actual trap is. More often than not it's after the gully. Did you get a plumber to inspect? Thanks for the advise. Had finally have the plumber to inspect and confirmed the water trap was forgot to put in. Now the difficulty is, to put the original water trap in, the tile on top will need to be removed first. What the plumber did was, cut the sides of water trap to get it smaller and slides into the waste gully. Of course the quality is certainly not as same as original one any more. Still waiting for a final solution from the builder. ... for months already. Re: No floor water trap in Bathroom? 7May 02, 2021 2:33 am OWilson87 It was also better for us to call the private immediately. a company that does this and it will help you with this. Because waiting a year for a response is too much! Good luck to you Thanks for advise. Plumber inspected and confirmed the water trap was missing... Suffered this smelling issue for more than a year, just because they forgot to put it in... Re: No floor water trap in Bathroom? 8May 02, 2021 2:33 am moudzj Further investigations by who? Might just be a filthy waste, stick your arm in and see what you can pull out. Better yet, call a plumber and have them check. Thanks for the advise. Had this checked by plumber and confirmed water trap was missing. If you have a floor waste, turn on your sink and put your ear down to the central floor waste and listen. If you can hear water running then they all connect there. If you… 10 12630 Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8930 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 14447 |
