Browse Forums Bathrooms and Laundry Re: Replace Bathroom Floor Grate/Drain 4Aug 06, 2021 9:43 pm Thanks for the reply. My old grate was just like your one size wise, but was white plastic. I pulled it out no problem, as it was poorly glued by plumber and replaced with 110mm grate, but it had gaps on the side which needed some extra grouting. Also the new grate was thicker so had to shave down some of the cement the old grate was sitting on…. It’s very annoying how 120mm grates are used when the standard seems 100-110mm at most Had a new driveway installed with a 6 metre long 150 x 150 channel drain and have since found out it has 4cm of water sitting at the bottom below the side pipe… 0 4859 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10728 |
