Browse Forums Bathrooms and Laundry Re: Laundry to bathroom conversion 3Oct 30, 2016 9:08 am Our Build123 Hey Luke, no need to recess if if plan on waterproofing over the screed. It's usually only recessed when the membrane is installed over a level slab or floor, to insure water will find its way into the waste without interference from the lip of the flange. Good luck with it! Thanks you, that`s really helps From the information posted it looks to me your rumpus room is nothing more than extended garage. That will present a number of challenges. Single brick wall between… 2 9028 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 12629 Because it only states 90mm not if it’s 45mm or 35mm and yes I do have the plans my question was specifically since it’s not the structural value and only to hold… 2 4153 |
