Browse Forums Heating, Cooling & Insulation 1 Jan 28, 2020 9:32 pm I am building a 34sq, single-story house in south-east Melbourne. By doing some research, I've found that as Melbourne is mostly cold so rather than refrigerated (electric) cooling/heating, GAS ducted heating + addon cooling would be economical in the long run. I've only found one product from Brivis with the Gas heating + addon Cooling e.g. http://www.brivis.com.au/star-pro-series/ducted-gas-heating/ http://www.brivis.com.au/dual-comfort-climate-system/ Can anyone suggest a better combination or another brand/product where we can use high efficient GAS ducted heating + addon cooling? Is there an option to install just heating first and add an addon cooling on a later date. Do I need to do anything extra while installing the heating so that it can accommodate the addon cooling at a later date? dymonite69 Can I please have your opinion as well? Read my first home build journey by clicking the following link Building with SJD Homes in 2020 - Charleston 310 Customised Re: GAS Ducted Heating + Addon Cooling Option 2Jan 28, 2020 11:48 pm 'Do I need to do anything extra while installing the heating so that it can accommodate the addon cooling at a later date?' You need to increase the size of the ducts. Ducts for gas heating is smaller than for cooling. Re: GAS Ducted Heating + Addon Cooling Option 3Jan 31, 2020 10:29 pm I'd say you haven't done your research very well. Reverse cycle AC (heat pumps) are the most efficient form of heating. More efficient & cheaper than gas, & this gap is only likely to widen in the future. I'd never consider connecting gas for a new build. Many, many people with existing houses are removing gas entirely from their home. Saving many hundreds of dollars a year on the daily service charges alone, before even considering gas usage. Check out the "Me Efficient Electric Home" group on Facebook. Aussie group with over 11,000 members & growing. Lots of good advice there. Install solar PV on your roof & you can run your heating/cooling for free during daylight hours. No doubt, when battery prices decrease, you'll be able to heat/cool your home for free at any time. Oh, your house is huge. Cut it's size down to a decent size, & heating & cooling costs will decrease too. Savings could be invested in improving energy efficiency, solar PV, heat pump domestic water, increased insulation, better building sealing with wall wraps, improved windows, & window furnishings. The list could go on & on. Your wallet & the environment will thank you. Re: GAS Ducted Heating + Addon Cooling Option 4Jan 31, 2020 11:31 pm ddarroch Many, many people with existing houses are removing gas entirely from their home. Saving many hundreds of dollars a year on the daily service charges alone, before even considering gas usage. Yep, did that 3 years ago. I would never ever have gas again and not primarily for financial reasons. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: GAS Ducted Heating + Addon Cooling Option 5Feb 26, 2020 2:16 pm Yep this is what I am investigating now as well. Moving away from ducted options and looking at split systems like this. https://www.daikin.com.au/our-product-range/ducted-system-air-conditioning Haven't looked at the costs yet. Re: GAS Ducted Heating + Addon Cooling Option 6Feb 27, 2020 9:55 am storewallAU Yep this is what I am investigating now as well. Moving away from ducted options and looking at split systems like this. https://www.daikin.com.au/our-product-range/ducted-system-air-conditioning Haven't looked at the costs yet. You've actually provided a link to the ducted system Re: GAS Ducted Heating + Addon Cooling Option 7Feb 27, 2020 11:02 am Thanks, which one from the Daikin range should I be looking at? Re: GAS Ducted Heating + Addon Cooling Option 9Mar 01, 2020 6:26 am So did a little more research. I am interested in a multi split system. However I like the look of vents and would prefer if possible to avoid the head unit in each room. I see there are the cassette units for larger rooms. Is there something similar for bedrooms which sits in the ceiling and not on the wall. I am looking for dual cooling and heating. Re: GAS Ducted Heating + Addon Cooling Option 10Apr 22, 2020 4:56 pm ddarroch I'd say you haven't done your research very well. Reverse cycle AC (heat pumps) are the most efficient form of heating. More efficient & cheaper than gas, & this gap is only likely to widen in the future. I'd never consider connecting gas for a new build. Many, many people with existing houses are removing gas entirely from their home. Saving many hundreds of dollars a year on the daily service charges alone, before even considering gas usage. Check out the "Me Efficient Electric Home" group on Facebook. Aussie group with over 11,000 members & growing. Lots of good advice there. Install solar PV on your roof & you can run your heating/cooling for free during daylight hours. No doubt, when battery prices decrease, you'll be able to heat/cool your home for free at any time. Oh, your house is huge. Cut it's size down to a decent size, & heating & cooling costs will decrease too. Savings could be invested in improving energy efficiency, solar PV, heat pump domestic water, increased insulation, better building sealing with wall wraps, improved windows, & window furnishings. The list could go on & on. Your wallet & the environment will thank you. ddarroch Thanks for your valuable suggestions. I am a first home builder so don't have much idea about the long term cost of heating based on gas vs electric and options available. Can you please suggest a couple of Good Reverse Cycle AC (Heat Pumps) unit with a good reputation, value for money and just a rough initial cost (That would really be awesome would help) Actually, The only reason we didn't select the "Reverse cycle AC (heat pumps)" because we didn't have much info about these units and because of the initial high cost as compared to the Gas ducted system even if we chose a 6-star heating unit. Read my first home build journey by clicking the following link Building with SJD Homes in 2020 - Charleston 310 Customised Re: GAS Ducted Heating + Addon Cooling Option 11Apr 22, 2020 6:38 pm The most efficient heating will still be radiant based system, e.g. warm floors hydronic heating system integrated into your slab. Plus several split aircon units + fans as an efficient cooling option. Re: GAS Ducted Heating + Addon Cooling Option 12Apr 23, 2020 7:55 am [quote="murtaza.sh":3niazkhf] ddarroch Thanks for your valuable suggestions. I am a first home builder so don't have much idea about the long term cost of heating based on gas vs electric and options available. Can you please suggest a couple of Good Reverse Cycle AC (Heat Pumps) unit with a good reputation, value for money and just a rough initial cost (That would really be awesome would help) Actually, The only reason we didn't select the "Reverse cycle AC (heat pumps)" because we didn't have much info about these units and because of the initial high cost as compared to the Gas ducted system even if we chose a 6-star heating unit.[/quote:3niazkhf] Firstly, a couple of articles on the issue. https://renew.org.au/research/all-elect ... as-report/ https://discover.agl.com.au/your-home/s ... icity-gas/ One of the most efficient reverse cycle split systems is the Daikin us7, but it's also the most expensive. I'd be looking at these brands, weighing up efficiency (& other features vs cost). Mitsubishi Heavy Industries (MHI), Daikin, Panasonic, Mitsubishi Electric (a separate company from MHI) & Fujitsu. The most efficient systems are ductless split systems (as ducts contribute to energy losses). But individual splits have an outdoor unit for each indoor unit. So if you have many indoor units this approach may not be the best, if you want to limit the number of outdoor units. In this case you may also want to look at ductless multi splits. Where one outdoor unit supplies multiple indoor units. I believe these aren't quite as efficient as individual split systems. You'd also have to consider what's cheaper, individual splits, or a multi split. You may end up with a single split or two downstairs, & a multi split upstairs. As noted above, along with the usual wall mounted indoor units, you can also get cassette units in the ceiling, or bulkhead units. Look good, but cost more I'd presume. Newbie question for flooring options. We are thinking of changing the flooring for bedrooms and passage area. Last time we looked at flooring options was almost 8years… 0 3780 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 14856 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
