Browse Forums Heating, Cooling & Insulation 1 Mar 08, 2019 7:53 am Hi, I have been living in my newly built house for a little over 3 weeks now and I have noticed that cool air is coming from the evaporative cooler vents when not switched on. I've had to use a space heater in my bedroom at night because it gets so cold. Is that normal? The evaporative cooler is a Brivis Advance. Any help would be greatly appreciated, thanks. Fairhaven Homes - Clovelly 191 Re: Evaporative cooler draft when turned off 2Mar 08, 2019 9:32 am That does not sound normal. It sounds like perhaps a seal or stopper is failing to shut off air flow - either passive flow or from wind outside. Second Time 'Round Re: Evaporative cooler draft when turned off 3Mar 08, 2019 9:43 am CalicoCat Hi, I have been living in my newly built house for a little over 3 weeks now and I have noticed that cool air is coming from the evaporative cooler vents when not switched on. I've had to use a space heater in my bedroom at night because it gets so cold. Is that normal? The evaporative cooler is a Brivis Advance. Any help would be greatly appreciated, thanks. Brivis evap coolers comes with motorised servo seal or just a basic non motorised version. If motorised probably its broken... Someone will need to come and check. Hi everyone I have a terracotta tiles roof When I climb inside the roof cavity I can feel that there is a draft inside the roof as the wind goes through the roof which is… 0 4957 1 3464 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 13775 |
