Browse Forums Heating, Cooling & Insulation 1 Nov 15, 2018 9:40 pm Hi , Can accurate modelling outputs be used to demonstrate that the modelled unit/house is naturally ventilated ? ( i.e how much percentage of the year ). I do know that the Nathers certificatesdo not indicate the level of natural ventilation. Is there any other output from the software that can be used to calculate or check the percentage of natural ventilation? Any feedback would be appreciated. Thanks, Deejan Re: Demonstrating Natural ventilation through accurate model 2Nov 16, 2018 2:15 am Ventilated through what? If your house is well insulated, natural ventilation will be more about how breathable are your walls on one side and how wide and for how long you open up your windows/doors on the other side. Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 8054 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7434 |
