Browse Forums Heating, Cooling & Insulation 1 Jun 27, 2017 7:41 pm Hi, I have recently purchased my apartment which has a ventilation issue especially within the built ins. I have a AC with a dehumidifier which I use. Would cutting a hole above the mirrored doors (which is plaster above) and placing a grill/vent make any difference? The walls are made of brick with render. See img -> http://imgur.com/a/M34xf [img=500x400]http://imgur.com/a/M34xf[/img] Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 5268 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 8054 |
