Browse Forums Heating, Cooling & Insulation 1 Dec 05, 2016 8:56 pm We recently moved into a Victorian home with a metal roof and have discovered insulation is minimal. From the couple of quotes we've had it seems like getting batts in the roof is difficult, with tricky access meaning they'll likely need to be broken up and then passed through. The alternative I've been recommended is Cellulose Fibre. Practically it makes sense for a roof with tricky access and likely lots of nooks because of the homes age. I am however worried about the product itself. Do you have any recommendations on which way to go? I am looking for an unbiased opinion, which is proving hard to find. Cellulose Fibre or Glasswool Batts? Thanks in advance! Re: Roof Insulation: Cellulose Fibre or Glasswool Batts 2Dec 06, 2016 11:00 pm You couldn't lift every 2nd or 3rd roof sheet to lay batts down? End of the day blow-in insulation is better than no insulation though any trades having to work in the ceiling space will hate you. Does the house have down lights? If so and they still use low voltage halogen globes then you'll need to ensure that they don't get covered with insulation Found the answer. The recommended distance is .... 1 5958 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3146 |
