Can't find PPR pipes and fittings (the only ones I have found are green, which is not good for my color scheme) in Adelaide for hydronic heating. Can someone help, point me in the right direction.
Thank you for your time
Browse Forums Heating, Cooling & Insulation Re: PPR (polypropylene pipes) 2Nov 11, 2015 8:27 pm Also curious about this, where is the pipe going to be visible? Not sure about them been PPR but there are several options for hydronic pipe systems - Tradepex (orange), Auspex (orange), Rehau (pink) etc My build with FHBD viewtopic.php?f=31&t=78344 Re: PPR (polypropylene pipes) 4Mar 30, 2016 4:46 pm Thanks for your help guys. I have decided to order everything including piping and heating panels from overseas. It'll save me the hassle of finding it here and paying triple the price for hydronic heating. 4 6155 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 6011 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11305 |
