Browse Forums Heating, Cooling & Insulation 1 May 06, 2015 9:15 pm Hi Everyone, We've recently had an Advantage Air system installed and it seems to be an never ending nightmare! The system is good so far but the company...they're making me wish I could turn back time! I was wondering, is there an expert that can come and inspect what they have done? Since they showed up on site to start installing stuff, it's been a nightmare! Any help or advice you have would be much appreciated. Re: Aircon help needed! 2May 07, 2015 8:39 am You should really have asked this question in the heating , cooling and insulation section, that's where most of the air-con questions are and where some of the industry pros put in their 2c worth... viewforum.php?f=20 Stewie Re: Aircon help needed! 3May 07, 2015 1:49 pm Hi with aircon ,heating , of equal importance to product chosen is the design and installation expertize , if any of these three aren, t up to standard then you probably would have issues, I would get a installer whom others use for hard jobs, get name from some big shop front stores, , and get his opinion has lack of knowledge might very well be the issue and thus not no how ti remedy. Re: Aircon help needed! 5May 08, 2015 10:49 pm Hi Beanie846 What exactly are the issues you're having? And whereabouts are you in Australia? Air conditioning and mechanical services works falls under the jurisdiction of the plumbing commission. In Victoria that is The Victoria Building Authority (plumbing). If you're suspect of their workmanship, then you can contact either the VBA or equivalent in your state/territory and arrange for an inspector to come out and site the work. If the job is of poor workmanship or non-compliance then the inspector will issue a notification for the installer to return to rectify at no cost to you. hth Re: Aircon help needed! 6May 09, 2015 7:05 am You could contact a mechanical building services engineer. They would be able to come out, inspect, and give you an unbiased report. Do you have any specific concerns with the installation? Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16261 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 16880 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 5325 |
