Browse Forums Heating, Cooling & Insulation 1 Dec 22, 2014 5:47 pm Hi there, currently in our rental house whilst building, with ducted Evap air conditioning. System is undersized for the house and we’re used to ducted refrigerated reverse cycle aircon, so considering our options for getting through summer a bit easier ( I know… first world problems! ) 1 - Install fans in rooms we use most (maybe 3 at most) and some whirly birds in roof (probably our cheapest option) 2 - Install fans and also a split system in the lounge we use the most Or, can you get reverse cycle aircon installed using existing outlets? I’m guessing yes, and also guessing it would pay to get new ducting. Most costly option, but may also add value to house… Thoughts? The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16262 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 16883 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
