Browse Forums Heating, Cooling & Insulation 1 Feb 21, 2013 10:06 pm Hi All, I'm looking at installing a Geothermal floor hydronic system in the new house run by a Water Furnace Heat pump. Just wondering if anybody has personal experience with either Geothermal and/or Water furnace? It will probably be running around 5 months of the year non stop. Any pro's or Con's or lessons learnt would be appreciated. Cheers, Ben A. You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18724 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 17242 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17984 |
