Browse Forums Heating, Cooling & Insulation 1 May 03, 2007 5:15 am I have a customer with some drips from this stuff. Anyone have some ideas on how to clean it up after it has cured? Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3202 Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 4434 There is nothing in the various codes and standards that puts this requirement on the builder to do. I think that is what you are asking. Don't waste time trying to get… 5 2919 |
