Browse Forums Heating, Cooling & Insulation 1 May 08, 2009 3:30 pm We definately will have solar hot water. Has any one had experience with copper u tubes and heat pipe collectors. Are they any better than the big panels? When building a new house do you get a rebate for solar. I know when you replace your existing one you can get $1600. Is it worth getting connected to solar electricity. Probably not, because the rebate is about to end and 3kw of power which is the max will cost around $35,000 and I'll pay that off in twenty years. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14862 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20671 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 25101 |
