Browse Forums Heating, Cooling & Insulation 1 Apr 14, 2007 5:44 pm Hi all,
We are at a decision point to cosider a solar powered system from Rinnai or Dux. Looking at the web sites of both, Rinnai's offerings look fairly simple (their web site in Aus just got updated to include them). Dux offer more of a range and seem to have been doing it for a while? I would appreciate people's views on the two companies. My preference is to support Dux esp. that they are Australian. The Siatros the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14803 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20643 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 25053 |
