Browse Forums Heating, Cooling & Insulation 1 Apr 29, 2022 10:27 pm Hi friends, I've choose to go with Daikin 20KW AC for my house. (42sq) but got the confusion whether I should upgrade to premium ? Got the quote of $3500 + GST to upgrade from Standard to Premium from the builder. Thoughts on, Is the upgrade worth it ? and the does it really cost this much for premium ? Thanks, Raj Re: Need suggestion to choose between Daikin 20KW Standard V 3Apr 30, 2022 11:16 pm Leona33 Better upgrade insulation and glazing. ^^ this! We upgraded to include anticon under the colorbond roof (wasn't a standard inclusion) and upgraded the ceiling and wall insulation. We also upgraded for acoustic insulation between floors and in walls around bathrooms, laundry and TV areas and double glazed the more exposed windows. The upgrade prices were surprisingly cheap and it can't be economically done after handover. Regarding Daikin standard vs premium inverter, we were quoted... 1. Provide Daikin 14kw Premium Inverter A/C in lieu of Daikin 14kw Standard Inverter A/C $2,000 2. Provide Daikin 16kw Premium Inverter A/C in lieu of Daikin 14kw Standard Inverter A/C $2,485 We went for option 2. The Daikin premium inverter model is a little more efficient... 2% less power input for cooling & 5% less for heating, and has a greater capacity.... for our 16kW system, 17kW vs 16.3kW for cooling and 20kW vs 18.2kW for heating. Also, upgrading from the 14kW unit to the 16kW gave us an additional 10% airflow capacity. According to online retail prices there seems to be about a $2,500 (excl. GST) difference for the Daikin 20kW systems... https://www.lawsonair.com.au/daikin-fdy ... d-inverter https://www.lawsonair.com.au/daikin-fdy ... ucted-unit No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11868 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9185 Thank for yes basically what to remove and what to add, where to place them 2 7806 |
