Browse Forums Heating, Cooling & Insulation 1 Mar 19, 2022 12:59 pm Hi, I’m trying to figure out how to remove the gas heating return air grille to do some inspection behind it. It’s a plastic grill, 460mm square, probably installed 20 years ago. There are no obvious screws, but tugging it from different sides shows very little movement anywhere other than top and bottom. The louvres appear to be in 4 sections, it’s not all one piece. I’m scared to pull it too hard in case it snaps - a quick search doesn’t find a same-size replacement. Picture attached, any ideas? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6578 0 1659 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12691 |
