Browse Forums Heating, Cooling & Insulation 1 Jul 15, 2021 4:43 pm Hi all; i am keen to understand from others if/how they have improved the insulation of their home. My house is 2 storey - lower storey is double brick - upper is brick veneer with gyprock and stud. what options are there to retrofit some insulation ? currently none in walls - only roof Also - in the roof i have batts sitting on the ceiling. Any benefit in doubling this ? Also any insulation for between the rafters (under the sarking) ? i was thinking maybe rigid polystyrene for here and the brick work at the end of the roof i live in Central Coast NSW if that helps no double glazing Any advise appreciated. Re: Retrofitting insulatiuon to single brick 2Jul 15, 2021 8:44 pm dsz8738 i am keen to understand from others if/how they have improved the insulation of their home. My house is 2 storey - lower storey is double brick - upper is brick veneer with gyprock and stud. what options are there to retrofit some insulation ? currently none in walls - only roof There are companies that can "blow" insulation into the wall cavity. Alternatively, you could clad the house in foam, and then finish over it (render or extra cladding). dsz8738 Also - in the roof i have batts sitting on the ceiling. Any benefit in doubling this ? Also any insulation for between the rafters (under the sarking) ? i was thinking maybe rigid polystyrene for here and the brick work at the end of the roof Yes, doubling the on-ceiling insulation will help. No point putting any up against the roof for warmth, but could be beneficial if heat was an issue as the roof cavity can be a big oven. For cold, just put more on the ceiling. dsz8738 no double glazing Glass and frames are very thermally leaky, so you might consider supplementary glazing. Depending on your window type, you can get good success. Hello All π We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 9705 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 21344 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8877 |
