Browse Forums Heating, Cooling & Insulation 1 Mar 03, 2021 6:19 pm Dear folk For learning purpose I was trying to google it before posting it but I couldn't find an answer I have got 10KW DUCTED SYSTEMS - Mitsubishi Heavy Industries installed on single story house which has 4 zones and 6 outlets ,,,,if I put a wall controller on the lowest 18C What the expected range for a grill wall outlet temperature should be ? comparing to inlet using a pocket thermometer Thx Re: Ducted system checking temprature for outlet and inlet 2Mar 04, 2021 11:57 am There are way too many variables to this to give a concrete answer. Those variables include: Size of home Insulation efficacy Heat retention in roof cavity Ducting quality Temperature outside How your outdoor unit is oriented(e.g. are you recirculating hot exhaust becaude you installed the unit facing a fence) Volume of air exchange Just to name a few. If your system size is reccomended for the size home you ar3 in and its not cooling enough, start there. There lots of things that could be contributing to that. On ours the thermostat inside the ducts that regulates the cooling coil was too close to the outlet and was registering cooler air and shutting off the cooling b3fore the house was cool. They just moved the thermostat further down the ducting and problem solved. Though it took several visits and the manufacturer t o come out and work it out. All about three months of dealing with it. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 10031 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
