Browse Forums What's New Re: Use of Structural Insulated Panels 61May 01, 2012 3:06 pm Yes, I think you are now correct in that they have developed their engineering now to the point where they can build 2 storey. This has occured over the last few months as I understand. 3 storey not yet, there is a whole new world of engineering required for that. Hope that helps. Russell 0414 398 586 Builders are people too.... Re: Use of Structural Insulated Panels 62May 09, 2012 11:18 pm It is worth looking into another option that is available now through the company MgO Board Corp in Queensland. They produce SIP panels with Magnesium Oxide(MgO) 'skins' or faces that are either 90 mm or 180mm (for external walls). The benefit of MgO is that it is waterproof, extremely fire resistant (is used in furnaces and the like),strong, can be painted or rendered just like a brick wall directly without need for gyprock or other sheeting. Is suitable for wet areas without additional lining. The insulating material they use is aerated magnesium oxide that has a texture somewhat like 'Hebel stone' or alternatively polyutehane. The fire resistance of these material goes from very good for polyurethane insulation to excellent for MgO insulating core. The prices ex Qld for the MgO core panels I was quoted approx $83/m2 for the 180mm thickness and $53/m2 for the 90mm thickness. i am waiting on a quote for the polyurethane insulation cores (with MgO skins) but should be less than the cost of MgO Very exciting stuff as it has all the benefits of other SIPs with speed and ease of build but none of the fire issues or off gassing issues raised here and elsewhere. The preceding may all sound like an endorsement - but we havent used these or other SIP panels as yet, but have been a long time researching the options for our build in Parkerville - happening soon... and these definitely seem the best and also reasonably priced option thus far, for us at least, as we are in a bushfire zone. Re: Use of Structural Insulated Panels 63May 17, 2012 10:00 am Quick comment that whoever and whatever system is used (they all have their advantages and disadvantages) that the supplier is able to properly 'panelise' your whole home so that it takes account for all the engineering, structural and services so that you end up with a genuine structural kit that will go together quickly and efficiently. Unfortunately, many suppliers/manufacturers are too focused on just making panels and leaving you with the headaches on site! Until we find a more switched on and responsibile Australian supplier we will continue to import kits from the US - they are far superior quality and much more accurate and, for example, at least 30% cheaper (landed) that Australian suppliers of OSB panels Builders are people too.... Re: Use of Structural Insulated Panels 64May 20, 2012 9:21 pm Builda - what about your contact in Qld you mentioned previously. You seemed impressed with their system - are you more leaning toward imported panels. Are there issues with certification of panels produce O/S - do they have to undergo specific Australian Standard testing or is there an International certification that covers Aust standards?? Re: Use of Structural Insulated Panels 65May 21, 2012 8:50 am fireflies, I drew a set of plans for a local builder a couple of years ago for his own house which is now about 90% completed who used these MgO panels for some of the external walls and also the floor to his lounge room. He like the R-values it gave him particularly the floor as he is going to have underfloor heating with travertine on top. I think he used 60mm thick for both. He didn't have any problems using it ( panels were fixed onto metal extrusions over 90mm studs for the walls and screwed directly to the 100mm floor joists for the floor). Stewie Re: Use of Structural Insulated Panels 66May 21, 2012 11:12 am The Qld supplier was for a metal clad system very similar to Bondor INsulliving that is made in Melb. The qld system is excellent however they are now only geared up for major projects and production line stuff - single homes is now something they do not do any more. For metal clad panels I would recommend the Bondor Insulliving product and you can easily google their details. For OSB clad panels we are looking to import For MgO Clad panels we are unsure as there seems be no local (Australian) supplier that has grasped the concept of a complete panelised kit that can be delivered to site - it is still a very labour intensive operation and in essence NOT a structural insulated Panel system (aka SIPS) but more than just a cladding option at this stage. Builders are people too.... Re: Use of Structural Insulated Panels 67May 22, 2012 1:48 pm Quote: For MgO Clad panels we are unsure as there seems be no local (Australian) supplier that has grasped the concept of a complete panelised kit that can be delivered to site - it is still a very labour intensive operation and in essence NOT a structural insulated Panel system (aka SIPS) but more than just a cladding option at this stage. By panelised kit do you mean something that incorporates both the cladding and framing components together or... Stewie Re: Use of Structural Insulated Panels 68May 23, 2012 12:54 pm Builda I know Paneco (MgO skins polystyrene core) do the system where plans are converted to panels that require no further machining on site but are fit together basically as a kit. From my preliminary chat with boss at MgO Panel Corp (MgO skin and either Polyurethane core or aerated MgO core) they appear to do the full 'kit' system where plans are made up into appropriate panels, services are channelled through the boards in the appropriate place. As far as cost I don't know how they would compare with OSB imports. Is there any issue about certification of imported boards for Aust Building Standards or do you know if there is an International Standard that covers Austr requirements. Reason I ask is there is a Canadian company Oasis which produce MgO skin Polyurethane core which works out about $40/m2. They are manufactured in China. Stewie D - had to smile - the advantages of SIPS is in part the speed at getting the walls up - 90% complete after a few years - the marketers would love that one! However it is good to hear that there is experience in that product out there. It seemed to me that the aerated MgO cores was a recent development from what the MgO Panel Corp fella had to say. cheers Re: Use of Structural Insulated Panels 69May 24, 2012 9:07 am In theory everyone can panelise the house into a kit at least that is what everyones marketing suggests. Reality however, from what I have seen, is a far different exercise and while success is easy on very simple single storey projects I know of plenty where it has been a disaster. Before spending any hard earned cash, ask for a few references from past clients with builds similar to what you propose. Builders are people too.... Re: Use of Structural Insulated Panels 70Jun 27, 2012 6:47 pm Hi Everyone, Average cost for face brick veneer construction external wall is about $155.00 /m2 PaneEco system is $50/m2 plus installation max $20/m2 i assume this, plus external render $25/m2, plus internal joint set $5/m2 That's a saving of $55.00 /m2 for external walls, plus saving for roof and ceiling which is another $40/m2, there is no saving for internal walls compare to timber studs. So on average 4 bed house i cant see how you can save more then $20,000 ? Has anyone compared real costs to brick veneer construction, and how much you can save? Quicker, it probably is quicker and you get better R value, but its going to be hard to convince clients to go this path. Any other builder offering this to their clients? Re: Use of Structural Insulated Panels 71Jun 28, 2012 9:11 am all the SIP suppliers tend to claim that their product saves $$ on building cost. However, in reality, you are up against the `novelty penalty' imposed by builders and unexpected costs of special fittings or renders. we had quotes for a custom designed ~180m^2 house with slab on ground - $340K using Bondor Insulliving versus $290K for the same house in brick veneer with timber framing! Re: Use of Structural Insulated Panels 72Jul 01, 2012 11:17 pm Prettygully Possibly the point you are missing is that if you are considering building with sips, then you are probably innovative enough to find alternatives to the standard cladding on the outside, and gyprock on the inside - maybe removing 2 trades and replacing both with alternative "green" cheaper solutions. If you do build in brick veneer and timber which will you have on the outside? Timber I hope - or you will defeat the purpose of this style of building. I will be building a sips house - floor,walls and roof in a few months. The sips will be osb-eps-osb of varieing thicknesses according to need. The roof I am going to prime and then paint with a waterproof uv reflective roof paint which will deflect 90% of the suns rays - 1/2 the cost of a basic colourbond roof, and a 1/4 the cost of colourbond maxicool reflective iron. The external walls will be primed, waterproofed and painted with a lime based "natural" paint guaranteed to last the life of the building or 100 years whichever comes first. Both applications I can do - I'm not a professional, but have boned up on how to do it. The cost saving in these two areas alone is very substantial. There are many many more far more interesting ways to go about this than the standard that has been around so long that it bores you rigid! Have fun Jeff Re: Use of Structural Insulated Panels 73Jul 04, 2012 11:26 pm Jeff, Have you any links to websites for the paints you are going to use? Here is a link to my photo album for the SIPs build we did in the UK. 9 days for 2 of us to erect the wall panels and 1st floor I-joists and decking !! http://photobucket.com/chardselfbuild Enjoy, Justin Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Use of Structural Insulated Panels 74Aug 16, 2012 2:33 pm Just signed a contract this week with a regular bricks and mortar builder to build a home extension in suburban Perth in SIPs. Extension will be 3 beds, combined living / dining and a bathroom - so pretty substantial (don't know sq m off the top of my head), and we are paying approx $50,000 more in a $500,000 build for SIPs. I'm informed that it's not the cost of SIPs that push the cost up, it's the cost of what comes with it - plasterboard interior lining (apparently more expensive to install than float and set, the norm for brick construction?), and battening and boarding the exterior. I'll let you know how it goes, and in 6 months you can come over ahd kick the tyres (metaphorically). Re: Use of Structural Insulated Panels 75Aug 16, 2012 5:07 pm That 10% premium is pretty standard additional cost if using the WA manufactured panels as they are very expensive. This whole SIPS sector of the building industry is undergoing rapid change and there are now very reliable suppliers from the US who we are able to import with and more cost effective (and I believe higher quality) than what anyone is producing in Australia. While I take the earlier point that the additional costs are the 'novelty factor', to be fair the cost of these locally made panels are exhorbitant. Also, what the novelty factor really means is that the early adopters to SIPS (ie: the home owners paying for it) are effectively paying for everyones learning curves as there is a lot to learn about the design, engineering, cartage, installation, erection and fitting off a SIPS house and these learning curves apply to all the trades involved - not just the builder and the erection crew! I have also recently been introduced to a polyurethane foam panel with OSB both sides that is currently undergoing testing and this panel is achieving the highest energy rating of any SIPS in Europe. THe point here is that this whole sector is very fluid and under constant change but I personally believe that SIPS building is here to stay and will only get bigger as it becomes more cost effective. Builders are people too.... Use of Structural Insulated Panels 76Aug 17, 2012 12:01 pm chardy We built our 2 storey house here in the UK 4 years ago with SIPs for the walls and found them to be a great system. 2 of us assembled the whole shell including 1st floor joists and boarding in just 9 days with no prior experience. Our SIPs are OSB face both sides with a 100mm Polyeurethane core, any supportive beams are Glulam. Inside we battened out to create a cavity for cabling/plumbing before plasterboarding the whole lot. Outside has a membrane then battens supporting a brick tile cladding system so looks like brickwork but isn't ! We move over to Perth later this year and would love to self build (owner build) again using SIPs but most companies in Australia seem to only do EPS cores which I am not keen on and not as good as PU in my mind - anyone know different or shall I set up a factory myself ?? Justin Chris here (bensdad aka pio) we are using an r9 panel system in Perth to build with we also use afs as well. I'll pm you the details. PPA 30/6/12, Land 28/06/12, Contract 7/9/12, Valuation 11/9/12, Prestart 13/9/12, Settlement 18/10/12, Building Permit Issued 18/10/12, Footings 30/10/11, Slab 31/10/11 Re: Use of Structural Insulated Panels 78Aug 21, 2012 2:14 am Steel, We ran our cables behind the plasterboard which was battened out from the SIPs. I'm not a great fan of chases through the insulation ! Builda, Good to see a OSB-PU-OSB panel may come on the market, nothing but good reports from me after 5 years ! Chris, Nice one, look forward to seeing your build when I get there ! Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Re: Use of Structural Insulated Panels 80Aug 25, 2012 6:36 pm 2 ways to do it here but it depends on local electrical regulations as to which is suitable. 1. A layer of plasterboard onto the SIP with gaps left for the cable drops then another continuous layer over the top - gives a more solid feel. 2. 25mm vertical roofing battens at 300mm centres and plasterboard over the top giving a nice clear cavity for the cabling. Hope this makes it clearer ! Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=64997&start=40 Good questions but the best answer will be obtained by visiting (ie: interviewing) a couple of house designers and/or builders and ask them. You may find it challenging to… 2 3373 Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 32129 |
