Browse Forums What's New Re: Have you heard of the stone Serpentine? 3Mar 23, 2016 2:24 am Michael S Joseph Lambert is serpentine stone is strong enough??? I am interested in putting but quite confused will it be a worthful decision?? Yes Joseph. Physically, serpentine is a high density and high hardness material, close to zero rate of moisture absorption, which is a desirable aspect for outdoor applications. As a surfacing material, it has greater acid resistance, more hardness and less porosity when compared to most types of granites. These properties coupled with its high bending strength make serpentine an excellent choice for exterior applications. Serpentine can be used for pools, driveways, facade cladding, barbeque counters, etc., in a variety of semi polished and rough finishes like sandblasted, bush-hammered, honed, etc. Well that was some explanation Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 40904 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7004 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5965 |
