Browse Forums Landscape & Garden Design 1 Jul 20, 2020 11:20 pm Evening all, Not sure how to best frame the question. I'm after advice as to what to do with the pictured area. I live on a steep block. The very front part of my yard is the lowest section. The soil is dense clay/slate. There are a number of cuts in the block but there is always movement of water through the earth. I would Like to occassionaly park here. Or leave a trailer here and ideally would turf it all but as you see, the area retains water. This pool of water has been here for about 5 or more days. What can I do to assist in drainage or make the area habitable for grass that won't always be a constant boggy mess? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Front lawn parking ideas, a steep block and water 2Jul 24, 2020 8:55 am first ask for advice from a drainage expert and/or council to see if they can install a drain under the path to the gutter and/or fill the area with big rubble..at least 50mm or bigger followed by hard packed gravel like a road base and forget about grass although you may find that that weeds will invade the space and eventually become mowable You could be looking at anywhere between $400,000 to $800,000 depending on so many variables including: 1. Site conditions - what material is being excavated 2.… 1 2141 Hi Everyone, One of my favourite parts of a build is when the temporary fence comes down and the home begins to reveal itself. It also means we are on the home straight… 103 372621 I recently finished my house and after landscaping, have begun to plan a fence. To be honest its been a bit of an afterthought so I'm after some much needed advice. The… 0 2776 |
